Hi everyone,
Following the update to version 1.18.1 on October 5th, my two Aqara Opple 6-button switches have stopped working; Homey isn’t registering any button presses.
I’ve already deleted and re-paired them—which took a bit of effort—but unfortunately, Homey still isn’t detecting any button activity.
Has anyone else had a similar experience or can offer some tips?
I’m a bit stumped, as they were working perfectly right up until the Aqara app update.
There were also some reports of that issue on the app topic. You might want to report it there:
Just a quick follow-up on the problem I’m having after updating to 1.18.1:
My two Aqara Opple switches have stopped working.
I also noticed the following in the Developer Tools—maybe someone has a tip, or perhaps there’s a bug in version 1.18.1.
…is also the case when you re-add the Oppel to Homey.
What are you referring to specifically?
The Problem is After Update Aqara App to 1.18.1 the aqara oppel Switch do Not work
Befor all was fine
And under 1.18.0 the device was correct in zigbee and conect with homey
Best to ask your question in the dedicated Aqara forum topic. Then de developer is also informed on observarion.
I’ve given up; the Oppel switches work perfectly fine with the Aqara hub, but there is no new firmware available, so I decided to go with a different 8-button switch (Icasa) instead, which works without any issues.
From what I’ve read, the Oppel devices have a limited Zigbee stack, and they are no longer being supported or pursued by Aqara.
