Hi Peter!
Why are you using static IP with the unifi app? For me there is need for static IP and MAC detection works stable.
There’s a german written hint on the iOS feature of “private IP” Unifi Flow Wifi? - #8 by RonnyW
If there’s more than one access point, you need to fix the roaming between them:
I created an advanced flow with “timer” to double-check connection before marking away.
Hope this helps
