Power camera via ceiling lamp
Had some smoke detectors hanging around and got a message on me phone but was like 7 miles away from home. Don’t ever wanna go through that again!
Sorry one question more, what exactly happend, short circuit somewhere? How did they shorted?
Bad wiring under her “stapelbed” of which I didn’t know it was even there. She did some cleaning of boxes under her bed and then took a shower. When she got out her room (next to the bathroom) was alr on fire. But I think some wires not properly fixed together. I know it has nothing to do with using black wire as if it was brown but u need to know a little of it before u start using this dangerous kind of jobs.
So for ontopic answer: In Holland we made rules for it and it’s against the rules and not recommended!
Wire thickness is not an issue in this case, leave it as is.
The outdoor connection was designed for a (more than) 40W bulb.
You are replacing it by a smart bulb (not more than 10W) and a camera (5W)
So the load is reduced with >50%.
So this solution reduces the risk of overheating because of load.
I agree with the above mentioned: if you do not know what you are doing: don’t mess with it.
