[PC-App-Windows] HomeWindow – control your Homey Pro from the Windows taskbar
Top 3 and the taskbar space: Confirm that they are using 2 lines and work well.
Your own icons: Confirm that it works well.
Camera pictures: I am not sure how it is supposed to work in your app, since the app does not show anything: no camera section, no live streaming. I am running 0.5.5
Homey app: Tapo camera shows both LIVE streaming directly or via rtsp streaming through an app called ONVIF Camera.
I suspect it is because Tapo requires me to set up a separate rtsp account to show it in Homey.
Quote from Tapo website:
A Tapo camera account is only needed if you want to access your camera through a third-party platform such as a NAS device, RTSP/ONVIF monitoring software, or a PC-based camera viewer. Using a dedicated camera account for these platforms keeps your main TP-Link ID credentials separate and secure. If you only use the Tapo app to view your camera, you do not need to set up a camera account.
I need to paste the rtsp in the URL info in TAPO camera settings in Homey
At last, a curious question: many of my flows have status. Cannot be started by hand. What are the conditions that would disqualify them?
Really annoying bug if you have a lot of taskbar icons
Sometimes it sits here, rather than on the left side
@Wouter_M Great to hear the home battery works! Eufy indeed gives Homey two pictures per camera. HomeWindow 0.5.6 is out, and now:
  • each tile says which picture it is, e.g. “Front door · Person detected”;
  • right-click a picture → Hide leaves it off the Overview;
  • Show hidden pictures next to the heading brings them back.
HomeWindow updates itself. Thanks for the heads-up about Eufy’s new app.
@Hiep_Hoang Thanks for confirming the top 3 and the icons!
Camera: HomeWindow shows the still picture an app gives Homey for a camera; it doesn’t play live video. Your Tapo gives Homey a live stream (RTSP) but no snapshot, so there is nothing to show yet. If the Tapo or ONVIF app gets a snapshot option, it will appear by itself.
Flows: a flow can only be started by hand when it begins with the card “This flow is started”. Flows that start on something else (a time, a device, a webhook) can’t be started with the play button in the Homey app either, so HomeWindow says “Cannot be started by hand”. Add that card to such a flow, or start it from another flow.
@deejayreissue Thanks, good find! With many icons the widget didn’t know where the taskbar buttons end.
HomeWindow 0.5.6 is out and keeps clear of them: when room is short it shows fewer biggest consumers, and it no longer appears on the right for a moment before moving to the left. HomeWindow updates itself; let me know if it still happens.
HomeWindow 0.5.7 is out (auto-update, or the installer from GitHub). Since 0.5.0:
  • Taskbar widget: the biggest consumers take two lines each, the widget stays at the left, keeps clear of your taskbar icons and no longer blinks (thanks @deejayreissue).
  • Camera pictures now really show up, and you can hide one with a right-click (thanks @Wouter_M).
  • Your own icons picked in the Homey app show in HomeWindow (thanks @Hiep_Hoang).
  • More in the diagnostics report.
A few of you asked whether you could give something back. That is now possible at ko-fi.com/wnijhof. HomeWindow stays free, a donation is entirely optional. Thanks!
Full list: Releases · WNijhof/homewindow · GitHub
Hi @WNijhof , nice project, I like the graphics.
Some wish list, if I may :
  • search box is actually filter, not search box (I don’t mind), also small x for clearing out the box would be usefull
  • variables - missing filter
  • notifications, also filter, search, marking multiple entries for deletions etc.
  • device overview, clicking on title to get bigger picture, would be nice (for graphs but also cameras)
  • taskbar widget is overlapping with other apps, when taskbar is full
  • in the panel, would be nice to eg. add/replace eg. moods by lights
  • batteries list could be multicollum
  • clicking again on opened device could close the details
  • devices type list some of the devices types more time
  • missing insights and device logs :wink:
  • missing hiding option for some consumers in the Energy tab
  • doubleclick on systray icon could open the full Window
  • filtering/searching seems to be quite slow
  • setting target temperature can be achieved by clicking only, not dragging the slider
  • in the panel, I don’t need to see that on Favorites, I see Favorites - I mean the little start on every device, flow etc :wink:
Anyway, really very nice Alpha, good job, looking forward to your development ! :clap:
@Sharkys Thanks a lot, and thanks for the list! Most of it is in 0.5.8, out now (HomeWindow offers the update by itself):
  • Search boxes have a small × to clear them, and filtering waits until you pause typing, so it should feel faster.
  • Variables and Notifications get a filter. On Notifications you can tick several and delete them at once.
  • Batteries are shown in columns.
  • A second click on an open device closes its details.
  • Double-click on the tray icon opens the window.
  • No more star on every item under Favourites in the panel.
  • The device types showed “Other”, “Car” and “Fans and cleaning” more than once: every Homey class without a title of its own got its own button. Now there is one button per title.
  • The target temperature slider can be dragged again (it broke off after the first move), and it stops on the device’s step.
  • Energy: right-click a device under the biggest consumers to hide it; “Show hidden devices” brings it back. A hidden device still counts in the home’s use, and it is left out of the taskbar widget too.
  • Panel: in Settings → “Tab next to Flows” you can swap Moods for Lights, which shows every light per room.
  • Click a camera picture on the Overview to see it large.
Two questions:
  • The taskbar widget over other apps: 0.5.6 and 0.5.7 changed how the widget finds where your icons end. Which version did you see it with? If it was 0.5.7, a screenshot would help.
  • “Bigger picture for graphs”: which graphs do you mean? HomeWindow doesn’t show a graph per device yet.
Insights and device logs are on the list; that’s a bigger piece of work.
Already testing, thank you ! :smiling_face_with_three_hearts:
It’s 0.5.7
0.5.7
You are right, sorry - those are “cameras” graphs - eg. clicking on it / camera view, would be great
…and I see actually it works now in 0.5.8 ;-))
  • btw when hiding it, how to unhide ? :wink:
If I may, few more observation (using locally connected) :
  • switching to Flows in panel takes like 30sec, seems it’s not cached, as even my cursor slowsdown :wink:
  • search box - the cursor, during edit, starts somehow in the middle
    search
  • will you please also add Lights, right ? Just raising, I think it’s not missed intentionally, no need to answer, it’s okay that it will take time :wink:
@Sharkys Thanks for testing so quickly! 0.5.9 is out now (HomeWindow offers the update by itself).
Unhide a camera picture: on the Overview, next to the Cameras heading, there is a “Show hidden pictures” button. It shows up as soon as one picture is hidden.
Lights: 0.5.9 has a Lights item in the sidebar of the main window, with every light per room, next to the Lights tab in the panel.
Flows in the panel: I couldn’t get it this slow here. With 600 flows the tab takes well under a second. 0.5.9 builds the flow tiles more lightly. It also writes a line to the log when a panel tab takes longer than 1.5 seconds, with the number of flows and folders. If it is still slow, could you send a diagnostic report right after it happens (Settings → About)? Roughly how many flows do you have?
Cursor in the search box: I’m not sure what you mean. Is it the text cursor that jumps while you type, or does it start halfway through the box? Which search box is it (panel, Devices, Flows…)? A screenshot would help.
Taskbar widget on 0.5.7: thanks. Could you post a screenshot of where it overlaps?
Hi, thank you :wink:
unhide
Found it, so it’s uhidding everything…just tested it, seems there is some delay on showing the cameras again but it works
So you are close to my number, I have 743 :wink: I tested that in 0.5.9 and first load took little bit longer but it’s fine now. It was strange because during the load even my mouse cursor start shuttering for a while… didn’t check the CPU load at that time, sorry.
log
Btw now I found out that when I tried to check logs, it’s empty actually, it points to directory C:\Users\USER\AppData\Local\HomeWindow .
When you enter the edit box, the cursor is positioned as shown on the picture.
obrazek
And when typing, it remains like that
obrazek
It’s just small cosmetic thing…
Yeah, I did already, it’s still the same
overlapp
Btw another think if I may - when changing to LIST or GRID, when changing it on DEVICES, it changes also for LIGHTS and vice versa. While for devices might be usefull to have GRID, for LIGHTs might be maybe better to have LIST (or simply independent view) because of the way it’s used.
Thank you for all the updates made so far :wink:
@Sharkys Thanks again for testing and for the pictures! 0.5.10 is out (HomeWindow offers the update by itself):
  • Lights and Devices each keep their own view now. List or grid on Lights no longer changes Devices, and the other way round. In the list, all rows have the same width.
  • Show hidden pictures: the pictures you had already loaded come back at once now, instead of after the next refresh.
  • Log: an empty folder was actually good news. HomeWindow only writes to the log when something goes wrong, so there was no file yet. In 0.5.10 Open log opens a log that says “No errors so far” instead of an empty folder.
  • 743 flows: thanks, good to hear it’s fine now. The first load builds all those tiles at once, which can keep Windows busy for a moment.
Taskbar widget: sorry, I missed that it was the same picture. The widget is supposed to stay clear of the last taskbar button, and on your PC it doesn’t. Your taskbar shows labels (“HomeWindow” next to the icon), which I haven’t tested yet. Could you tell me your Windows version and the setting Combine taskbar buttons and hide labels? After updating to 0.5.10, a diagnostic report (Settings → Updates → Send diagnostics…) now also shows where the widget went and which taskbar buttons it found, which would help me a lot.
Cursor in the search box: thanks, now I see it. Here the cursor and the text start right after the magnifier, like the grey hint text. Is the red line Windows’ Text cursor indicator (Settings → Accessibility → Text cursor)? And which display scaling do you use (Settings → System → Display)? Then I can try to reproduce it.
Hi, this is just my red line to illustrate, where it shows :wink:
Hm, right, using 225% because of the resolution of 3440x1440 :wink:
That was only example, basically any Windows app overlapps.
It’s 26H2 and I have Combine taskbar buttons = Never (also tested with “Only when full”, and it’s the same.
Done and again, thank you :wink:
Thanks for the screenshots and the diagnostic report, both helped a lot. 0.5.12 is out with two fixes.
Search box
Your screenshots showed it clearly: the hint starts right after the magnifier, but typed text started about 30 pixels further in.
That was a bug of mine. Every text box applied its padding twice. Fixed in 0.5.12: typed text now starts where the hint was.
Widget over the taskbar buttons
Your report explains it. HomeWindow asks Windows which buttons are on the taskbar, so it knows where they end.
On your PC it found 28 buttons, but not the Start button and none of the program buttons. The last one it saw ends at 310 px, so it thought the rest of the taskbar was empty and put the widget on top of your programs.
Your Windows build seems to report the program buttons differently from the builds I tested on. In 0.5.12 the search also looks for other kinds of elements, and walks the whole taskbar if it still finds neither Start nor a program.
I can’t test it on your Windows version, so I’m not sure yet that this is enough. If the widget still covers a button after updating, could you send one more diagnostic report? It now also lists what kind of elements your taskbar shows, so I can match them exactly.
Scaling
The report shows a 48-pixel taskbar at 100 % on the 3440×1440 screen, so for the widget the 225 % doesn’t matter.
Isn’t it maybe because my start button is aligned fully to the left, while icons are centered ?
Anyway, I like to Homey data widget so much, so that I start combining the panel, like on MACs… you changed my habbits after 25 years of using Windows :rofl: don’t worry about that if nobody else reports that. :wink: And yes, widget is still covers over app button even in the latest version.
Search box is fine now, thank you.
One more problem observed … I wonder where is this FVE Battery value on widget coming from ?
My FVE :
On the Widget :
battwidget
Can I request a new feature: a quick peep at recent usage by showing a graph of power consumption of the last, say, hour or something configurable in Settings.
Graph (copied from insights) showed below as a demo
One can activate this graph by, say, hovering over the taskbar for over 2 secs.
Just a suggestion.
Thanks! Good to hear the search box is fine now, and that the widget changed a 25-year habit :grinning:
Battery value on the widget
HomeWindow found more than one device that Homey Energy marks as a home battery. It added up their power and averaged their charge, so 47 % is the average of your FVE battery (40 %) and another device, probably the inverter.
In 0.5.13 the Energy page has Battery counts from (like Solar counts from). Switch off the device that should not count, and the widget and the Overview show your FVE battery only.
Widget over the app buttons
Start at the left with centred icons is not something Windows 11 itself can do, so I guess a taskbar tool does it (ExplorerPatcher, StartAllBack, Start11, Windhawk or similar). Which one do you use?
Such a tool can draw its own buttons, which HomeWindow then cannot see. Could you send a new diagnosis from 0.5.13 (Settings → About)? It now also lists the windows inside the taskbar, which should show what the tool puts there.
Good idea, it’s in 0.5.13.
Graph on hover
Hold the mouse over the taskbar widget and the tooltip now shows a small graph of the house’s use, below the numbers. Settings → Appearance → Graph on hover sets the period: 15 minutes, 1 hour (default) or 3 hours, or off.
One limitation
The graph is built from the live readings since HomeWindow started, so right after a restart it is still short. It fills up as HomeWindow runs.
As always, appreciate your receptiveness and lightning implementation.
The graph is working perfectly and a great addition.:heart::star_struck:
Just out of curiosity: Do you know what other weather info Homey can provide out of the box? I am using a Homey extension to get rain next hour (mm) and wind speed (m/s) since I don’t think Homey has them.
Anyway, great if we can get some additional weather info in the expanded window estate (something like the info I mention above).
Hm, using StartAllBack since the time of Windows 11 release but already have forgotten that I used this feature :wink: … report sent but as I mentioned, I will be anyway using combining buttons on taskbar, too many apps opened at the same time anyway …
Perfect, thank you.
