[PC-App-Windows] HomeWindow – control your Homey Pro from the Windows taskbar
Really nice improvements on every release :grinning_face:.
The pop-up window (next to the clock) allows the views of each tab to switch from a tile to a list view. Though the toggle is there, I am not able to change the default tile view into a list view on both the Flows and Favorites tabs.
The Camera Images section in the main window also contains non-camera images from apps. As an example, the images from the Dutch weather service (KNMI). Since I don’t have actual cameras in Homey and the list of non-camera images is quite long, would it be possible to collapse or hide that section? Or maybe an option to choose which apps source that section.
Thanks, great to hear the graph works for you!
What Homey’s own weather gives
Out of the box Homey’s weather has the temperature, humidity, air pressure, the condition (sunny, cloudy, rain…) and a forecast per hour. HomeWindow already shows those on the weather card. Rain amounts and wind are not in it, so you were right to use an app for them.
Rain and wind in HomeWindow 0.5.15
The weather card on the Overview now picks them up from your devices. If a device measures rain or wind (a weather station, or a weather app on Homey), they appear on a line of their own below humidity and pressure.
A value of its own from such an app, like rain in the next hour, keeps the name the app gives it. With more than one such device, the first one by name counts.
Signed in with your Homey account?
Then Homey doesn’t give its own weather to other apps, so the card used to stay empty. Now HomeWindow takes the temperature and condition from a weather app on Homey, such as OpenWeatherMap or Open-Meteo. Without one, the Overview says so, with a button to switch the weather off.
Let me know if yours shows up. If it doesn’t, tell me which app it is, then I can check which values it gives Homey.
Thanks for the report, and good to hear the battery is right now!
StartAllBack
Your report showed it clearly. StartAllBack draws its own program buttons, and Windows doesn’t report them to other apps. So HomeWindow saw only StartAllBack’s buttons next to Start, which end at 310 px, and thought the rest of the taskbar was free.
What it can see is the window that holds your program buttons, and that starts at 611 px. HomeWindow 0.5.15 uses that: when it sees no program buttons, it puts the widget in the free room before that window, between StartAllBack’s buttons and your icons.
On your taskbar that room is about 300 px, which should be enough for the widget. If it isn’t, HomeWindow first drops the biggest consumers.
Combining the buttons is fine too; the widget then still stays out of their way. Let me know where it ends up for you.
Thanks for the reply. The overview does not pick up wind. I am not sure how useful the info about humidity and pressure for the average user. If I can have my picks about additional info (to the temp and weather forecast), I would suggest: feel like temp, rain next hour (mm/h) and probability (%), Wind (and gust if possible, m/s) and direction (SSW…)
I am using Weather Forecast | Homey
Your app does pick up those additional info inside the extension.
As a suggestion: why not add the additional information right in the new chart so the users can glance at it quickly and don’t need to open the full window or the weather tab?
Thank you, glad you like the updates!
List view for flows
You’re right: the list/grid button in the panel only switched the devices, while flows always stayed tiles. In HomeWindow 0.5.16 flows, favourite flows and moods follow it too. As a list they show one per row over the full width.
Camera pictures
HomeWindow shows every picture an app gives Homey, and the KNMI maps are such pictures. In 0.5.16 you can deal with them in two ways:
  • Right-click a picture → Hide all pictures of this app. That hides all KNMI maps at once, and new ones from that app stay hidden too.
  • Click the Camera pictures heading to fold the whole row away. HomeWindow remembers it.
Show hidden pictures next to the heading brings everything back.
Thanks for the screenshots, they help a lot!
Rain works, wind doesn’t yet
The rain from the yr.no app shows up, but the wind doesn’t. HomeWindow looks for Homey’s standard wind value, and the yr.no app probably names its wind differently. The cut-off line (“Rain next 6 hours 3,50…”) was my mistake; in the next version it continues on the next line.
Could you send a diagnosis?
Settings → Send diagnostics… (near the bottom). It lists the values your yr.no device gives Homey, with their exact names. Then I can pick up wind, gusts, direction, rain probability and feels-like temperature properly instead of guessing.
Your wishes
Good ideas, and I’d like to do them once I see the diagnosis:
  • Feels-like temperature, rain next hour with its probability, wind with gusts and direction.
  • Humidity and pressure as a choice, so you can leave them out. Others may still want them.
  • The weather lines in the tooltip with the graph on the taskbar widget, so a glance is enough.
Diagnostics file was sent to your email.
Thank you, unfortunately the widget switched to left and resist to switch over to right, despite of changing the settings :slight_smile:
widget
Thanks for the diagnosis, that told me exactly what I needed!
Why the wind was missing
The yr.no app calls its wind measure_wind_strength1, with a 1 at the end. HomeWindow only looked for the standard name, so it skipped it. HomeWindow 0.5.17 picks up such numbered values too.
What the weather card shows now
From your yr.no device, on the line below humidity and pressure:
  • Feels like 8°
  • Rain next 1 hour 0,4 mm (80 %), with the chance from the app
  • Wind 7,8 m/s SSW, gusts 12,6 m/s
Settings → Humidity and pressure switches them off, so only your picks stay.
In the tooltip
Point at the taskbar widget and the rain and wind lines are above the graph, so a glance is enough.
Thanks for the screenshot, that made it clear!
My mistake
In 0.5.15 the widget went to the room before your program buttons whenever HomeWindow couldn’t see them, and that ignored your choice of Right.
Fixed in 0.5.17
That room is now only used with Left. With Right the widget sits next to the notification area again, where you want it.
With combined buttons there should be plenty of room there. Let me know if it ends up on top of an icon.
Excellent. Working very well
If I may suggest a couple of further refinements for better readability:
  1. Round wind speed to the nearest whole number and rainfall to one decimal place.
  2. Put: Feel like in same line as real temp
Rain one line
Wind next line. Following is an example of what I mean
Cloudy 11°. Feel like 7°
Rain: 0,5 mm (71%). Next 6 hours 0,7 mm (55%)
Wind: WNW 10 m/s (16 m/s)
  1. Also suggest to drop from the newly developed chart: Home consumption, From the grid and EV Charger since the information is already shown on the taskbar. At least, don’t show the information that the users have disabled in the Settings. Example: I have disabled the “From the grid” and “EV charger” (since the info are not relevant for my case), yet the chart shows the two lines.
Also a question: The number on the top right of the consumption chart, is it the max consumption during that time frame? Again, thanks for the great work.
Thanks, good suggestions! They’re in HomeWindow 0.5.18.
Weather lines
Rain now has its own line with one decimal, and the wind the line below in whole numbers:
Cloudy 11° · Feels like 7°
Rain next 1 hour 0,5 mm (71 %) · Next 6 hours 0,7 mm (55 %)
Wind WNW 10 m/s (gusts 16 m/s)
On the weather card the feels-like temperature sits next to “Cloudy”, under the big temperature. Humidity and pressure, if you keep them on, come last.
The tooltip
It no longer repeats what the widget already shows, and leaves out anything you switched off for the widget. So no more From the grid or EV charger lines for you. What stays: the weather in words with rain and wind, the home battery charging or discharging with its power, and the graph.
The number at the top right
Yes, that’s the highest use in the period of the graph. It now says “max” in front, so nobody has to guess.
I would love to be able to set a permanent filter on simple flows which have a start button (or just hide all those without)
A huge list of advanced flows that can’t be started by hand isn’t a desirable workflow
Thank you. Exactly what I was asking for.:+1::blush:
Good idea, thanks! It’s in 0.5.19, out now (the app offers the update).
Startable only
On the Flows page there is a new switch at the top right, Startable only. Turned on, it hides every flow without a working start button: flows without the card This flow is started, and flows that are switched off or broken.
Panel too
The choice also applies to the Flows tab in the panel, and HomeWindow remembers it. Your favourite flows always stay visible.
