Noirot radiator / Intuis Connect Gateway
Hello All,
I have several Radiator from the
brand : NOIROT Model : Tectonia
that can be manage by “Intuis Connect” gateway.
Didn’t succeed to connect that to the Homey pro.
Do you have a way to do it ?
regards !
Bobby
Hi @Bobby_83 ,
The information I got about the NOIROT Tectonia is not very informative.
It seems a they work with Netatmo thermostats and those you can control with Homey.
And probably you can only use a plug that can be controlled by Homey and switch the radiator simply on and off, depending on temperature, time absence, etc.
But may I just got it wrong. Then I just can tell you, that there is no App in Homey (You can search here, that is designed for NOIROT devices.
hello ,
I finally manage to connect all my radiator like so :
Connecting the intui connect gateway to homey with Homekit controller.
en then all radiator was detectable thought homey too.
