New app Panasonic Comfort Cloud
You’re absolutely right. Thank you very much for getting back to me.
I was making some changes to the accounts and re-registered/logged in the device several times, which explains what you saw in the logs.
Everything is working perfectly now.
Thank you very much for your help and support. I really appreciate it.
Best regards,
Radek
Hi.
A huge thanks to @Johnny_Espesete - I’ve missed this app!
My specific use is to guard my summerhouse, and start the heatpump if temperatures gets below a certain threshold.
Also I’d like to ensure that the tenants isn the house uses the nanoe-X function, so I’d like to force-enable this.
Would it be possible to add the nanoe-X enable/disable function to the flows?
Kind regards
Dennis B
Denmark
Hello! That should be possible! Ill get back to you :slight_smile:
Frost/temperature guarding for your summerhouse is already possible today — create a flow with “Outdoor (or Indoor) Temperature drops below X” as the trigger and “Turn on”/“Set thermostat mode” as the action, no update needed.
Nanoe force enable/disable is now added as a flow action card (“Set Nanoe Mode”) in the next release (v2.1.31) — you’ll be able to force it on for your tenants regardless of what they set locally. :slight_smile:
@Johnny_Espesete - Thank you so much!!!
I already had the temp guard set up for the summerhouse. Works perfectly!!
And now - Nanoe-X too - That was fast reaction!! :+1:
My deepest thanks from here - and a donation on it way.
Also - You’ll be part of my evening-prayer - If I ever start praying at night :smiley:
Kind regards Dennis
Thank you very much for the kind words! And an awesome donation! Its great that this little app is of good use for so many people! it started as a little personal project and things have escalated :smiley:
There is actually 1000+ users on this thing so any changes needs to be carefully tested so i don’t brake the flows or the app itself for so many people!
Hey @Johnny_Espesete - really great app!
I noticed one annoyance and was wondering if you had an idea. The available temperature range when creating an action seems to be affected by the heat pump’s current mode. This means that if it’s in frost protection mode then I can’t select a temperature over 15C. Similarly if it’s in heat mode then I can’t select lower temperatures.
Maybe you could just allow the temperature selection to be in the widest possible range?
Thanks!
I will look into it!
Hi, and thanks for the kind words!
I looked into this. The temperature range follows the mode because the app only has one range for the target temperature, and Homey’s built-in “Set target temperature” card uses it as well as the slider. The app can’t give the flow card its own wider range.
I considered just allowing the full range all the time. I decided against it for now, because it could let flows send temperatures the unit doesn’t accept in other modes (for example below 16 °C in Cool). I can’t test that properly without risking other users’ flows.
For now you can work around it like this:
  • To set a temperature above 15 °C, turn Frost Protection off first.
  • Use the app’s own Frost Protection action card to switch it on and off in your flows.
I’ll keep it in mind for a future version if I find a safe way to do it.
Hi @Johnny_Espesete,
I can’t add my Panasonic heat pump with Panasonic Comfort Cloud v2.1.32 on Homey Pro. Right after I press Sign In during pairing, it shows “401”.
  • My Panasonic account uses plain email + password. It is not linked to Google or Apple.
  • The same email and password work in the official Comfort Cloud app, and the heat pump works there.
  • I tried with the email in lowercase too, with the same result.
  • It’s an air-to-air unit (wall-mounted split).
  • I’ve also restarted/ reinstalled the app several times.
Diagnostics report: b64134f9-8540-4d07-aee6-c964651c3e9f
29d75b69-f932-4dbe-abd0-7ed485e6a158
Thanks for the app!
Hey all. Just to ask is it me or it stopped working after homey security update? I cannot login anymore if I want to add new device.
Same here for me I get 401 report a8079b90-9d78-47c7-b30e-4224c5b80ea6
Im getting multiple reports on this. Investigating
update the app to 2.1.33 and send me a new diagnose report. I have added more error logging to pinpoint the problem. I think maybe Panasonic have made changes to their API.
To talk to Panasonic’s servers, this app identifies itself as the official Panasonic Comfort Cloud phone app, including a version number. Panasonic’s servers started rejecting the version number the app was sending, and answered with code 4106: “New version app has been published”. Your credentials, Homey and the app were fine. The failure came after the login had already succeeded.
What’s fixed in v2.1.34
  • The app now sends a version number that Panasonic’s servers accept. It takes the number from the official Android app’s listing, because the iOS number was ahead of what the servers support.
  • If Panasonic rejects a version, the app automatically tries known-good ones, so a future mismatch should fix itself.
  • Sign-in failures now log Panasonic’s actual response, which makes future problems easier to diagnose.
Hi Johnny,
I’m having an authentication issue with Panasonic Comfort Cloud v2.1.34 in Homey.
The error is: OAuth step 3 failed: 400 invalid username
The username is definitely valid. I logged completely out of the official Panasonic Comfort Cloud app and successfully logged back in through Panasonic’s authglb.digital.panasonic.com login using the same Panasonic ID email address and password. My phone number is also registered and SMS verified.
Restarting Homey did not help. The Panasonic unit is working normally in the official Comfort Cloud app.
Could this be related to Panasonic’s current OAuth/authentication flow? Is there a workaround or newer/test version I could try?
Thanks,
Arne
Hi!
If you could provide a diagnostic report i can take alook at it :slight_smile:
Hi Johnny,
Update: I managed to solve the problem by adding the Panasonic device through my.homey.app on my PC. Using exactly the same Panasonic ID and password that gave OAuth step 3 failed: 400 invalid username in the Homey iOS app, authentication succeeded from the Web App.
The heat pump is now connected and working correctly from Homey, including on/off and status feedback.
This therefore seems to be related to the authentication flow from the iOS Homey app rather than the Panasonic credentials.
Arne
Strange! I am unable to test this myself since i’m on a samsung but if you got it running thats good :slight_smile:
