Netgear Meural
For about a week now I am a proud owner of a shiny new Homey Pro. Now I am looking to connect my Netgear Meural 2 to it, but there is no app for it. I found, however, this in GitHub: GitHub - edwinw6/homey-meural: Control your Netgear Meural digital art frame with your Homey. Set the brightness, turn it on and off and display your own images.
It seems to be exactly what I am looking for, but I have no clue what to do with it. Does anyone know how I can install this on my Homey?
Hello Percy, and welcome to Homey forum.
Download the zip
and you’d be able to install it by CLI (command line).
(It should be compatible with the Pro 2023, because the SDK version = 3)
That worked inmediately. Thank you very much for your help, I can now control my Canvas 2 vie Homey.
Hi
Is this still working for you? Bought a Meural Canvas 2 as well and tried to connect it to my homey, but when trying to login with my Netgear account in homey, I always get an invalid credentials. However, I am sure that my netgear login is correct, as I am using a password manager. Any ideas on what the issue could be?
Despite using a pw manager, please try the following:
  1. Copy your password
  2. Login by manually entering your username, and pasting the password.
Hi @Peter_Kawa thanks a lot for the fast response. Unfortunately, that did not work. Tried all combinations:
  • Type in username & password manually
  • Type in username manually & copy paste password
  • Copy paste username and password
    All with the same result :frowning:
Maybe changing the Netgear password helps. I’m out of options.
Tried that as well already. Just to be sure we are talking about the same account. I am able to login with my credentials here: https://my.meural.netgear.com/ . Is this the correct account or is there another one? Do I have to enable something to allow API connection? Wonder if it could be a location issue. I am located in Switzerland.
Could not find a solution for my issue, but found a plan B by using the local web interface as documented here: GitHub - GuySie/ha-meural: Integration for NETGEAR Meural Canvas digital art frame in Home Assistant
