I’ve been messing around with a flow to get something basic done, but can’t manage to make it work :-/
Context : A neo coolcam PIRV2 is placed in the kitchen. If it is getting dark < 5 lux, than the lights should turn on when there is movement.
First I created a more simple flow, but I’ve been working now on another more robuust flow, that doesn’t work:
Flow a:
If lumonisity has changed
AND tag luminosity < 5
THEN set variable kitchenDARK to true
Flow b:
If there is motion
AND variable kitchendark is true
THEN enable light 1 , enable light 2 and stop countdowntimer KITCHEN
Flow c:
If there is no motion detected
THEN start countdowntimer KITCHEN 5
Flow d:
If Countdowntimer KITCHEN is empty
THEN disable light 1, disable light 2
Flow e:
If luminosity > 10
THEN set variable KitchenDark to False
Whats happening: it’s dark, motion sensor works, put lights won’t turn off…
Maybe it’s too late for me to work on logical flows, right now, but this is very annoying me
That’s exactly what I used (using the timer and all) als tutorial. Thanks btw for this clear tutorial @Rocodamelshekima. But somehow, things got really weird. I use this way of working for another motion sensing bulb, and it works just fine. Something is happening in the relation between motion & lux I guess…
Have some Flows similar as written by @neluz with Neo CoolcamV2-Sensors. All have a “Timer-Function” without an extra Timer-App and using Lux-Values. Working fine.
FLOW1 When Motion-Detection On And Sensor-Lux is not greater 5 And MyBulb is Off Then Turn On MyBulb
FLOW2 When Motion-Detection Off And Sensor-Lux is greater 7 And MyBulb is On Then Run Flow3 after x-Seconds
Flow3 When Flow is triggered And Sensor-Lux is greater 7 And Motion-Detection is Off And MyBulb is On Then Turn Off MyBulb
Flow2 has the “Timer-Time” (after x-Seconds). It starts Flow3 for turning MyBulb off. MyBulb will only turned off if there is a) No Motion-Detection and b) Lux-Value is greater 7.
The difference of 2 Lux (5 = On, 7 = Off) is to prevent always On and Off of MyBulb when there is e.g. fast Cloud-Movements on the Sky.
Also checking the State of MyBulb to prevent Homey always to send On or Off to the Bulb when new Movement-Detected-On or new Movement-Detected-Off (see Flow), for a better performance of Homey itself and a lower Traffic on the Network.
Using in Flow1 the Motion-Sensor of the Room/Area for turning On MyBulb, also in Flow3 to check the State of MyBulb.
In Flow2 using the All-Device-Card. If one of the Sensors at Home reporting Motion-Detection-Off MyBulb in e.g. Room1 will be turned Off when meanwhile the Sensor-Lux of Room1 has reached a Value greater 7 (and Motion-Detection-Off in Room1) equal where a Person is at Home (e.g. MyBulb is in Room1 and a Person is in Room2) > Saves Energy.
So the releation between Motion and Lux is, on my Homey, working as expected.
Thanks for your reply @CyberSponk !!!
Well, the problem is thats I can 't combine the tip sensors from 1 device in one flow: for example, Wegen motion-detection on, I can 't use the lux-sensor in And function. Maybe thats potje problem. Eager to know how @neluz Managed to do so
The problem was in the THAN, but I realized I was stukje in my logic: I used the motion sensor in the when and the lux sensor in the AND. I should use a logica function reading out the density
