Neato D3 connected question
Hi Manfred,
The card can act on the following status changes:
  • Vacuum cleaning
  • Spot cleaning
  • On docking station
  • Charging
  • Stopped
I’m not sure If “stopped” is also “stuck”. It can also raise events on battery level changes. You can also give it the following commands:
  • Start cleaning
  • Start spot cleaning
  • Stop
  • Back to docking station
So I guess that if you automate it to “Start cleaning” and after let’s say an hour issue “Back to docking station” if there is a “stopped” event in between something is wrong and it’s probably stuck.
This all seems great, but I can’t get it to work. After connecting the connection seems to work for a small amount of time, but just as you get enthusiastic about it there is a red exclamation mark and the entire connection is out and you have to remove and repair everything again.
