I successfully added 5 devices (namron thermostat) but when I tap on any of them I get this message Could not get the device by id. I’m a new beginner with Homey ![]()
Any solution to the problem? Hopefully someone can help me
Thank you
Thank you
Hi Dario,
Welcome.
You can find support links at the homey.app store Namron app page.
It leads you to Github issue tracker. You can look in the solved issues for a solution, or create a new issue to report your problems
Hi Peter,
Another user had the same issue after the latest update of the Namron app, using a test version of it solved the problem (Gihub issue tracker page). Works as it should now! ![]()
Thank you!!
