Hi
I have set up a few Namron GU10 bulbs, which keeps loosing connection to the hub. I may re-pair, but again they loose their connection. I have reset the bulbs several times but it does not help. Has anyone any experience with these bulbs?
Hi
Welcome , …
there is more then one app for Namron devices for Homey, check which app you use and contact the developer of your app.
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum! post here.
This particular Namron app only supports GU10 bulbs, which appear to be zigbee enabled.
I guess your zigbee setup should be tuned to optimize the signals.
The first step is to set the channel numbers of both 2.4GHz wifi and zigbee in a way they interfere the least.
See bullet number 3 in this how-to below;
Please read the other info as well ![]()
