Missing Scope Error with set variable action
Suddenly getting “Missing Scope” error when working in flows and appears to be when setting a variable.
Simple test flow:
  • When: this flow is started
  • Then: Set “Test Variable” to “Testing”
Try to save the flow, and receive the error “Missing Scope”.
Any suggestions.
Was using the set variable in some advanced flows, which were working, but now I can’t make any changes to the flow because when I try to save the changes I receive this same error.
Figured out the issue on my end. I was logged in as a guest user.
