Migrating from 'Zonnepanelen' to the *SolarEdge* Enphase App, any hints?
I’m planning to migrate from ‘Zonnepanelen’ App to the SolarEdge App.
Can’t find info on how-to nor a [App][Pro] thread about the SolarEdge App.
I’m useing the ‘Zonnepanelen’ App in quite some flows. Can I install the SolarEdge App. next to Zonnepanelen without screwing everyting up and then edit my flows ?
Not every app from the Homey App Store has its own forum topic. The information on what you need to do with the SolarEdge app can be found in the description in the App Store:
To your question: If there are no restrictions from SolarEdge regarding the number of users accessing the SolarEdge account at the same time, then it should be possible to install both apps in parallel, as both apps connect to the SolarEdge Cloud.
My assumption is based on my previous experience with cloud services. I have no personal experience with these apps!
If this doesn’t work for whatever reason, you can use @martijnpoppen 's script [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices to repair the flows if you have to delete the Solar Panels app first and then install the SolarEdge app.
However, there may be problems if the two apps use different types of flow cards. Please inform yourself in the linked topic first.
I don’t have issues with repairing flows… Just like to know in advance, like to plan things like that instead of ad-hoc :slight_smile:
Right, anouther one
Also marked ‘official’…
I’m lost right now. Not doing anything as long as ‘Zonnepanelen’ is still working.
Wondering wich official App will be the Official one :roll_eyes:
The developer of the official Solar Panels App is no longer active and unfortunately hasn’t been responding. Combined with the fact that most manufacturers now offer more than just solar panels, we decided to split the Solar Panels App into separate apps for each brand.
You can run the new apps alongside the old one, making it easy to transfer everything at your own pace.
My mistake, I’m clearly on to many projects at the same time (heatpump, HVAC, Homey) and work..
I’ve got Enphase Enlighten so that’s the app I need…
In this case, you can simply use the new Enphase App that @Emile has created. We’re also working on expanding the app’s functionality by integrating the Envoy gateway— which you likely have installed as well—over the local network.
The tag “official” does not mean anyrhing….
For example: the Frank Energy app is “official”
But there has not been any response to questions, not via the “[app]” section in this forum nor via the mail linked to the app.
I mailed Frank Energy and they responeded that homey is not supported by them.
But.. to stay on topic..
Think that is the best plan for now, doing the same
The “official” tag next to apps means that they have been tested and verified by the Homey team :wink:
As to Frank Energie, that app is developed by an agency in cooperation with Frank Energie themselves. Can you send me your question via DM? I’ll check with the Frank Energie team.
Good to note here as well. The Frank Energie thread on the forum seems to be auto generated. I don’t think their team or the agency is active on our forum.
The app threads which are created by the account @AppStore, are created by moderators. This is done to bundle the number of topics and questions. These app threads are not actively monitored!
