The command is “homey app install”
The problem was the wrong cmd envoirement….
Next one, I can’t find the devices. My home is on 192.168.2.xxx and my devices are on 192.168.1.xxx
Both are connected, with the first router (192.168.2.xxx) connected to the second one (192.168.1.xxx).
What can be the solution?
This is tough, this doesn’t have anything to do with any app not functioning. We are getting in the realm of network configuration.
All I can say is that those networks need to be able to talk to eachother. You could try adding by IP manually but I doubt in your case it is the solution.
hello, i installed your app succesfully and included it to the energy-dashboard but while it was discharching the staus indicator ( i use gridpower, batterypower shows no value ) says it was charching, is there a way to fix that
Are you stil working on this app?
