Hi everyone!
I have two Homey units, one in my house and another one in my garage. I wonder if an event in one place can trigger a flow in the other? For example, if I have a light sensor in the house, can I make that one trigger a flow to turn on lights outside the garage? They are both in the same wifi network, using Homeplug over the power cables.
Best regards Peter
Hi @Peter_R13,
welcome to the forum
Sure thing you can realize that. In many ways too.
Spontanously two methods come to my mind: webhooks and MQTT
You can search for apps using those two terms and will find a lot of info on the forum as well.
Thanks for reply!
I have read about MQTT and I think it’s a treasure of opportunities. However a bit over my level of programming skills… So my hope is aimed towards webhooks. I’ll try to read about it!
///Peter
IFTTT is basically dead since the paid model introduction.
Also it is not very reliable, has lots of delays and at times commands do not get through at all.
I would not recommend to rely on it if you have time critical tasks.
I feel the same. Pity, IFTTT could be such a useful bridge between different echosystems.
I have now finally mqtt broker client hub on my homeys, but I don’t understand how to make flows that trigger the other homey?
I can see in the log that it’s working sending packages to the other homey.
If I have one device in the client homey og several devices in the broker homey and I want to include the device from client Ina flow from the broker, is that possible?
