Luxom - Domotics - TCP/IP ASCII interface
Would the Athom Homey be able to connect to an existing Luxom domotic environment?
The (ideally bi-derectional) communication works using ASCII messages over a fixed TCP/IP adress (example “*S,0,2,01;” to switch on a light).
More info can be found on:
http://luxom.be/uploads/ppfiles/27/LUXOM_ASCII.pdf
http://luxom.be/uploads/ppfiles/28/LUXOM_ASCII_extended.pdf
Kind regards,
Tomas
There is a community app request topic to ask for adding device/brand support.
Please use layout presented in the first post when adding a request for this brand/device in the same post.
Hi Tomas,
I have the same question!
Did you find a solution to connect Luxom to Homey?
Hi Filip,
I haven’t bought the Homey, as I would only like to invest in it when I am sure it would work with Luxom in one way or another.
Do you have any experience with other applications & Luxom? (e.g. Openhab).
Tomas
Thomas,
No, I still haven’t found a solution to connect Luxom to a “visualisation” software. I think openhab is very difficult to use.
Mvg Filip Vandenbroele
