Long Press on Lutron Caseta Pico Remot
I have an advanced flow using a pico remote. I would like for a short press of the center button to dim a light and a long press of the center button to turn off another light. The problem is that when I long press the center button both flows are run.
Any help would be appreciated.
I just tried and get the same. And then I tried all the buttons and they all work like that for me.
This was in the settings of the Pico device. Apparently that is the way it works.
So extending the long press time stopped the double run of flows?
No. I read that to mean regardless of the setting the single press will always be triggered.
Yes you are correct, I misread it
I believe a similar issue was discussed in the following topic:
Indeed. That’s similar. I added some extra’s to it in the mean time. Will update the topic.
