Lights switching on randomly
anyone experiencing lights switching on completely randomly?
I have 4 innr GU10 Lights that switch on every now and then on random times (mostly during the night). In the Homey app they still appear to be switched off when this happens. This happens not very often, but is super annoying. The lights are only connected to Homey and I did a reset of the lights but no succes.
Since a few weeks an even stranger thing is going on, my Hue ground spot which is connected through a Hue bridge is also switching on… (separate of the innr lights) and strangely, this does appear in the app of Homey:
But in the Hue app no automations whatsoever, also here I’ve done a reset of the light but every now and then this happens…
Yes, since a few weeks my stairs lights turn on whenever they feel like. It’s a Lidl zigbee bulb with a Aqara zigbee PIR to activate it.
Please install the Audit app, it logs everything for you to see what’s going on.
I also advice to add Simple Log flow cards to flows involved.
You also can add conditions to flows involved, like “and when no one is asleep”.
This could limit the chance of lights waking you up.
This can be the result of a flow turning on the light by a dim command; but it just says “turned on by App Y”.
So, this device log is only partial useful.
I was having the same issue. I determined that Alexa thought it was in away mode and was turning lights on and off randomly to make it appear we were home.
