Hi, I want to create a flow which turns on my lights only on Monday and Wednesday morning at 7:00 AM. I can’t find it in the and… options of the flow. I tried to put both weekday in the flow, but that doesn’t work. Does someone have a solution for this? Thanks!
Thanks. I couldn’t find the or… option, but I can see it now when you move the action.
The easiest way would be the Cronjob App. There you can enter all necessery conditions in the When… card. It is easy to use and reliable.
The advantage is that there are no flows that start at other days than Mondays or Wednesdays.
