Hi
i have a few simple flows that control my lights, but they have a life of their own. Some times they work - some times they dont. And i cant see why.
The flows i like this. if there is motion and the time i between 23-06 then dim lights to 20% else dim to 100% and set at timer to 360 sec - after this a different flow turns off the lights when the timer hits 0.
I have been using Hue sensors (3 units) and hue bulps. On the sensor i can see the led indicating motion lights up but the lights does not turn on - other times it does.
I have added a card that animates the led ring on Homey to see i the flow is running - it is not always the case.
So the problem must be with the sensors it seems, so i have gotten new Xiaomi Aqara sensors and replaced my Hue sensors - sadly the result is the same. The new sensors register motion but the flow is not activated.
As of now the hue sensors i back together with the Xiaomi to see if a greater number of sensors can force Homey to react - it does not seem to be the case…
I use two flows to control the lights in this part of my house because of the layout - one sensor can not cover i all. So sensor 1 activates flow 1, and sensor 2 activates flow 2 - the flows are the same.
Distance to the sensors i between 15 cm to 3 meters so range cant be an issue
can anyone tell med what is going on before i go crazy ?
