Keypad
Hi everyone,
I’m looking for a keypad that lets me arm and disarm my alarm system via Homey. Preferably via Zigbee, but Matter or Wi-Fi is also a possibility if necessary. I was interested in the Frient Intelligent Keypad, but I’ve read that it doesn’t change status when you disarm the alarm via the dashboard, and you can only set one code.
Are there other devices that can do this and integrate well with Homey
Thanks in advance!
There’s few of those,
Ring has one:
No clue if it fits your preferences.
I use ring for this and have set flows to arm and disarm my system. However I have the whole alarm system by ring so for full functionality you do need the base station too
Keypad only has limited flow cards with the Ring app.
It is ZWave though i believe so maybe it will pair as it is but probably as an unknown device and so not much in terms of options.
Do you use home assistant? I believe You can add a virtual alarm keypad in HA as a helper - this can then be added to Homey as a device using the community app. Ive not used this option but it could be worth an explore if you already do or have a way to run HA. Might achieve what you need without extra hardware
Eufy did do a wifi version - i think some are still available but its a discontinued product
Cant think of any other options sorry!
What about this one?
You can also use RFid cards with it.
Is that an other keypad than the non-preferred one?
This one is actually exactly what I’m looking for, if the issues I’ve listed here have been resolved in the meantime.
This is the same one. However if the listed problems i have with this keypad have been resolved, it would be exactly what i’m searching for.
