Issues with Flow to automate HVAC using Motion/Temp Sensor
Hi @Player2 ,
The first one cannot work, as ALL does never fire from different When triggers.
The second one is a good start, but it is only one possible event, that starts the flow.
Either you start with each of the three possible events in your first try, check the other two each time in an And conditions and then you can combine them with the Any card.
Or you combine all three triggers with the any card and then check all three conditions again.
One example is in the multi condition test.
Kind regards, Dirk
