Is there a way to stop a flow from execute actions?
I’m trying to set up a flow to turn off lights forgotten on during day after a couple of minutes.
The problem is that once my flow starts:
When
Lights on
Then
Power off after 120 seconds
Notify me
Notification push me even if lights it has already turned off
How can I stop notifications when not needed?
Thanks for your help
Split it up in two flows…
At to the Then:
Start flow “notify me”
Flow “notify me”
When
This flow is started
Then
Mmm sorry but…how/why this should not notify me when lights is turned off?
Thanks
This goes in you’re own flow after THEN
Start a flow “check light” after 120 seconds
When this flow is started “check light”
And
The light is on
Then
Send a notification
So if the light is on after 120 second you get a notification.
Nice it works!
Thank you
