Does Fibaro Universal Sensor, FIBEFGBS-222, compatible with Homey
No, it is not listed in the Fibaro-App.
Probably not since it is not listen in the Fibaro apps supported devices list. If you wanna add this to your home automation system, it’s probably your best bet to asak the devloper of the Fibaro app if it can be added.
the FGBS-222 is called “Smart Implant”, not “Universal (Binary) Sensor” like the previous version was.
But yes, it is supported
Oh, I’m sorry. I got confused with the name. I thought you meant the new Smart Modules.
The Smart Implant FGBS-222 is supported, of course.
Sorry again.
I connected 3 DS18B20 sensors on it and the temperatures are displayed on my phone BUT … I can’t create a flow that sent me a push message when a certain temperature is reached.
Ex. When temperature sensor 3 is less then 4 degrees THEN send push…
The only “when” fonction available is “when temperature sensor is changed” I can’t define a treshold or a value…
Any Ideas ?
Sorry, I can’t help you, because I don’t use a Fibaro Implant myself.
Have you used the search yet?
yesssssss, of course… but I’m afraid that her’s no solution for it…
Try the magnifying glass on the top right and search for: How to use tags in a flow.
Click here if ur lazy.
P.S. I can see if u clicked the link.
I clicked the link…
Really great! I learned a new thing. Thanks a lot !!!
