πŸš€ Introducing HomeyScriptKit - A Framework for Building Better HomeyScript Scripts
Hi all,
I’ve been working on a small framework that makes it easier IMO to build custom HomeyScript scripts for use in flows. After using HomeyScript for a while, I found myself wanting more structured ways to pass parameters and handle results, so I built HomeyScriptKit to address this.
Key Features
URL-like Argument Passing
Pass parameters using intuitive URL-style strings
hsk://sonos/toggleSurround?ip=192.168.1.1&volume=50
Standardized Result Handling
Unlike standard HomeyScript cards that only make results available with inline scripts, HSK provides consistent result tagging that works with external scripts, enabling better flow chaining
Third-Party Package Bundling
Bundle npm packages directly into your scripts to leverage the JavaScript ecosystem for more powerful automation (your mileage may vary depending on package complexity - always test thoroughly!)
What’s Included:
  • Complete development workflow with debug and production builds
  • TypeScript support for better development experience
  • Example scripts (including a Sonos home theater controller)
  • Comprehensive documentation and step-by-step guides
  • Testing framework integration
Perfect for:
  • Creating reusable script libraries
  • Building complex automation logic
  • Sharing scripts with the community
  • Developers who want more structure in their HomeyScript workflows
The framework handles all the boilerplate - you just focus on your script logic. Check out the repo for examples and detailed documentation on getting started.
Repository: GitHub - indieisaconcept/homeyscriptkit: Extend your Homey's capabilities with custom HomeyScript automation scripts
Would love to hear your thoughts and see what scripts the community builds with it!
Note: This requires basic TypeScript/Node.js knowledge for development, but the compiled scripts work like any other HomeyScript.
Sounds interesting, well done
FYI I have added experimental support so you can sync scripts directly to your homey via companion CLI tool. Full details below.
