That is worth a try. So you mean
Condition: any status
AND: status mowing
THEN: do the magic
AND: status mowing
THEN: do the magic
Yesss
Works like a charm! Thanks a lot for the hint.
Trying to download but install button is not available. Any tips?
Iām currently looking for robotic mower option, seems thanks to Homey integration, Worx might be winner⦠can someone please post flow card options (incl. and and then actions?). Iām interested if itās possible to trigger rain detected from Homey because of the rain/sun garage Iām considering as wellā¦
Thank you.
Thank you a lot - but this is just status, right, eg. you canāt force ārain detected stateāā¦
Yes. Just statuses reported from the mower. You canāt force rain detected, no. Unless you poor a bucket of water on it ![]()
FYI, seems that also Worx Landroid M500 Plus (2nd generation) works so far fine (at least I see data).
Btw, checking ioBroker in parallel, seems there are also some other interesting attributes like⦠I guess @Martin_Verbeek itās not something you would like to implement, right ? ![]()
Anyway, thank you for your Homey integration, actually Iām surprised seeing it only in the Community app and not the official store but I donāt mindā¦just actually found it accidentally while it deserve official place.
Hello same problem for me. Have you found a solution.
Thank you by advance
Are you logged in ? Have you installed the Comm.store addon on your Homey?
Anyway, itās not related to this app, so you may want to ask in the HCS thread.
Btw, just to let you know, Martin has released new version with added new parameters
Looking forward to have those new parameters also in Insights ![]()
V2.2.0
Added some informatinal fields (gradient, inclination, timeExtend, batteryVoltage and Temperature
Hello Sharkys
I have tried to installed it without sucess with folowing advise (install small software on my window 11 computer). My computer, my mower and my homey are on the same 2.4ghz wifi network but instalation option from aplication still not available.
I will tried to asked help to the HCS tead as you sugest.
thank you
stƩphane
Thank you for your great work. I successfully installed your app on my Homey, but I canāt add my Landroid WR141E. I just get the message āNo new device foundā
Should I do something else before trying to add my automower ?
Landroid is connected to wifi, I can see it in the official Landroid app and the integration in Home Assistant is also working, so I donāt think that the device might be the problem.
Thank you!!
EDIT : Forget it, I found the solution, just had to go to the settings and add my Worx credentials ⦠Sorry ! Iām still a beginner with Homey ![]()
no problem, when any issue or question or ask for improvements, drop me a message
Just waiting for Insights and it will be absolutely perfect now ![]()
are these okay?
You are the best!
Thank you, it looks fantastic⦠finally I can disable MQTT integration for Worx ![]()
Is this message after the restart? If not could you pm me large chunk of log previous to the restart
Martin Verbeek
Unfortunately itās just before the restart
Thatās why I decided at least to share state of the app and device. After restarting there isnāt any errror in the log, all seems to be normal. It happens like 1-2x per a week, nothing serious.
