For Homey I had a good working Self Hosted Server (paid version) on old PC hardware. I have new PC hardware for testing , so I created an 2nd Self Hosted Server (trail version). After testing I deleted the Shelf Hosted Server. But know when i want to install a app on the Self Hosted Server (on the orignal paid server), I get message self hosted server is disconnected. Does anyone can tell me how to fix this? because I already delited the trail version of Self Hosted Server.
Are you sure that you deleted the correct instance? Also, does https://my.homey.app/ still work?
Try turning off Wi-Fi on your phone (this forces cloud connection). Also, you should tap the Select Homey dropdown and select the SHS again just in case the old SHS was somehow still cached
Turning wifi off dif not helped. I also tap the Select Homey dropdown and select the SHS did not helped either.
In that case, you should report it to Athom:
I will take contact with Homey. Thank you
