[HowTo] Homey Pro (Early 2023) - Getting started (With Early Access)
@Henk_Renting
It will blink that is not the problem.
To clarify, If the normal repair does not work:
Goto the device by opening the devices settings and choose maintenance.
That way your flows will be repaired too.
Then when switching off and on 6 times, during repair / pair mode, it will not reset the bulb but actually do de repair/pairing?
@Peter_Kawa and @Henk_Renting
I just went and tested it.
It Works!
Thanks!
Seems it simply took much longer than I realized to get the beta version after having enabled it in the Play store
A few hours later and I got the update!
