How to use the GET Web logic flow card and retrieve return values
Hi There,
I need help to connect homey to my thermostat.
So I have to communicate through web requests…should be easy…but I’m facing misunderstand regarding the way to use it with homey cards.
So my request is the folowing :
http://192.168.x.x/conditions.cgi?token=abcdefgh
This returns a very simple json with temperature and humidity => here is the complete feedback
“temperature”:23.7521,
“humidity”:49.6349
My question is : how to extract those 2 values and put them into logic variables.
I also tryed the Http Request app without any chance.
Is there someone to help me ?
Thanks in advance
That’s the app you need to use, though. What exactly did you try?
I try to do this but not sure I’m in the right way.
So when I click on the variable I didn’t reach anything.
Sorry my app is in French
I also tryed to type this in http request app but the variable list still left empty… not completely sure for the path.
{“method”:“get”,“protocol”:“http:”,“hostname”:“192.168.x.x”,“path”:"/conditions.cgi",“headers”:{“token”:“tokenid”}}
The card you’re using requires the Better Logic app. In that app, you need to create a variable (called “variable” in your example).
Alternatively, there’s a “GET JSONpath trigger value” action (“THEN”) card available:
With that card, you can use the same URL and JSONpath expression, and let it execute a trigger (which you can name yourself, let’s say my_trigger).
Then in another flow, you can act on that trigger using the trigger (“WHEN”) card “JSONpath value”:
For that card, you enter the trigger name that you used in the previous step (my_trigger).
The card has a tag for the received value.
Hi Robert,
Thanks for the detailed help !
I made it working.
Have a nice evening
Mathieu
