How to 'supress for' in flows (Like you can in Alexa)
So the questions in the title but. In Alexa I can trigger a routine and then ‘supress for’ a certain amount of time so it’s not retriggered again. How do I achieve this same behaviour in Homey flows???
I would use a Timer from the Chronograph app for this. At the end of your flow start a Timer with the wanted suppression time and at the beginning of your flow (right after your trigger) check the Timer and only continue if it is not running.
Yeah I happen to use that construction @CaptainVoni describes
Here’s the visual:
Cheers all
