I tried for many times but I don’t see how I can set the time of my timer in Countdown or chronograph. How does it work. When I select a timer in a flow I can choose a new name but I don’t understand where I can set the time in seconds etc.
You first have to add a timer in the setting page of the countdown app.
In the Home app goto, apps, countdown, then right top corner click settings, app setting. The you can make a timer.
Now when making a flow you choose the timer and then you can also fill in a time in seconds, minutes and hours.
You can also use the Chronograph app. That app will continue with counting after, let’s say, a restart of Homey.
And you can make a timer just by filling in a name in the card of the flow.
The color changes within a secon after starting the flow instead of 60 seconds
Ok. Makes sense!! Thank you for your support. I will study this and make some samples to test
OK. Good luck.
If you have questions, ask it.
There are a lot of people who want to help.
