I am trying to learn homeyscript. For a absolute NOOB and a non-programming type it is quite a steap learning process.
I came across this information.
How do I interpretate this? And how do i make use off it in Homeyscript.
It would be great if I could start a flow with a script.
I also stumbled upon this rule but cannot get it working. I did add the id off the flow.
- You can ignore the OAuth scopes, Homeyscript has a fixed set of scopes (which, I don’t know) so it’s not something you have control over.
- that the method is
async means it returns a promise
- the (single) argument
opts is optional (although it being optional doesn’t make sense because what would triggerFlow() do without any information on what to trigger exactly?)
- when you pass it, it should be an object with one mandatory property
id and an optional property state.
id is the id of the flow you want to trigger (this is something you have to infer from the documentation, it’s not explicitly stated)
- nobody knows what
state means
In your example code, instead of triggerProgrammaticFlow use triggerFlow.
I get this as return, does it mean you can’t access flows from a script?
Yes, sounds like Homeyscript isn’t allowed to do that. There’s nothing you can do about that (apart from asking Athom why they have decided to cripple Homeyscript like this).
