How to get a Google Home connected device into Homey?
I only see the reverse question in the forums, but not this one:
I have screens that do come with a Google Home compatible app, but it does not seem to have native Homey integration. So now I want to import this device via the Google Home connection. I connected Google Assistant and added Homey to Google Home. I see a “sync” option, but that one only describes status sync. I don’t want to import all Google Home settings into Homey, and the “sync” options is not very transparant in what it will actually do.
Is there a way to get such apps easily into Homey?
Which screens are they? Maybe it’s Tuya based
It’s not possibile to import Google Home devices into Homey. I tried this but google doesn’t expose these devices as a possible import. You can’t control them externally
Stephan
What is the device, in particular manufacturer?
There is usually an app in the Homey App store you can use to load the device into your Homey system, you can then decide whether to keep the two devices or just have one instance.
Apps for Homey Pro | Homey
Just select the version of Homey that you are running.
Stephen
