I would like to control the downlights in my living room Aeotec Wallmote Quad. The downlights are divided in two sections, each with a Aeotec Nano Dimmer.
I have all units integrated are added to Homey but I cant find a way to set up the Flow.
I am also new to create flows with the phone interface.
Can’t help you with your specific question, but this might help you with creating flows in general:
Automation in Homey is handled by so-called “Flows”.
A flow consists of three phases:
WHEN - the part of the flow that controls WHEN or WHY the flow should start, eg. that a button has been pressed or an event has occurred.
AND / OR - the part of the flow that checks IF stated conditions is fulfilled or not, eg. that it is a certain day or a device have a certain status.
THEN / ELSE - the part of the flow that EXECUTES something, eg. lighting a lamp or calculating a value.
The three parts of…
You can also create and edit flows from your PC:
https://flow.homey.app
and also tweak that page a little to your need:
Of course everyone is happy With the new Flow for Web App!
but some where more happy using a flow editor in three columns.
The nice thing is with a extra CSS file you can customize the way your browser presents it.
Lucky for me (and you) some Homeys on Slack already shared what they like.
As I am no CSS guru I asked how they did. Thanks to Rob and Bjorn I got some Code.
The people using Linux with fe Epiphany probably know how to use it.
As I use Chrome most of the time I installed the ext…
Thanks for the reply, I used the old PC interface where it was easy to define the flows.
