I am trying to set up flows for my Honeywell T10 thermostat using Residio app. I am having multiple issues:
Homey app and T10 thermostat do not work on the same temp standard. T10 is set for Fahrenheit but Homey continues to display Celsius. When setting up flows, the temp standard changes with the task and sometimes displays things like “23.5 degrees F”.
Also, the Homey app does not seem to be able to set the temp or the cooling set point. I’ve set up numerous flows using time to change the temp and set point but the commands don’t seem to work.
I can get Homey to change to run the schedule. That works in flows as expected HOWEVER there does not seem to be a way to turn off the schedule. The thermostat allows Schedule, Temp Hold and Permanent Hold but Homey does not have a setting to enable either hold so after you use an automation to run the schedule you can’t get it to not run a schedule.
I’m trying to pick an automation system but I cannot commit any dollars when some basic functionality is either wrong or doesn’t work and the features are incomplete. Frustrated with Homey,
