HomeyScript : getting error : Invalid Token: string
I have a script that checks if a devic is not connected anymore, and it works perfectly in HomeyScript.
However, when I try to integrate it into flows to capture the result, I encounter the following error: *Invalid Token: string: Invalid Token: string
I try to replace log with return I have the same issue.
Thanks for your help.
This is the homey script :
// Obtenir tous les appareils
let devices = await Homey.devices.getDevices();
// Initialiser un tableau pour les appareils qui ne répondent pas
let nonResponsiveDevices = [];
// Parcourir chaque appareil
for (let deviceId in devices) {
  let device = devices[deviceId];
  // Vérifier si l'appareil est indisponible
  if (!device.available) {
    nonResponsiveDevices.push(device);
// Afficher les appareils qui ne répondent pas
if (nonResponsiveDevices.length > 0) {
  console.log('Appareils qui ne répondent pas :');
  nonResponsiveDevices.forEach(device => {
    console.log(`- ${device.name} (Zone : ${device.zoneName})`);
} else {
  console.log('Tous les appareils répondent correctement.');
The script doesn’t have a result, it doesn’t return anything nor does it set any tags.
Thanks Robert, I might be wrong, I’m running the script within a flow, It should return a text? I try ti replace console.log with return but I get th same error.
You have multiple calls to console.log(), which one did you replace with return?
Thanks Robert for your help, I re-think with ChatGPT the script, this one works fine :+1:
const devices = await Homey.devices.getDevices();
const zones = await Homey.zones.getZones(); // Récupérer la liste des zones
  // Vérifier si l'appareil est injoignable
    // Récupérer le nom de la zone en utilisant l'ID de la zone de l'appareil
    let zoneName = zones[device.zone]?.name || 'Zone inconnue';
    nonResponsiveDevices.push({ name: device.name, zoneName: zoneName });
// Afficher les appareils qui ne répondent pas ou un message de confirmation
  let deviceList = 'Appareils qui ne répondent pas :\n';
    deviceList += `- ${device.name} (Zone : ${device.zoneName})\n`;
  return deviceList;
} else {
  return 'Tous les appareils répondent correctement.';
