Good morning, I was trying to create a weatherstation with arduino using a:
- DHT22 (temperature/humidity sensor)
- Rain/Snow sensor
- NodeMcu V3 ESP-12E
This is working standalone as webserver. After testing it, i’ve tried to change my code, so I could add it to homey with the not further developed homeyduino app. But I’m receiving error:
This is my full arduino code:
#include <ESP8266WiFi.h>
#include <Homey.h>
#include <DHT.h>
#define DHTPIN D4
#define DHTTYPE DHT22
#define RAIN_SENSOR_PIN A0
DHT dht(DHTPIN, DHTTYPE);
const char* ssid = "changed";
const char* password = "changed";
// Statisch IP-adres instellen
IPAddress staticIP(192, 168, 2, 219);
IPAddress gateway(192, 168, 2, 254);
IPAddress subnet(255, 255, 255, 0);
void setup() {
Serial.begin(115200);
dht.begin();
pinMode(RAIN_SENSOR_PIN, INPUT);
WiFi.begin(ssid, password);
WiFi.config(staticIP, gateway, subnet);
Serial.print("Verbinden met WiFi");
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("Verbonden!");
Serial.println(WiFi.localIP());
// Homeyduino setup
Homey.begin("TempHuminRainSensor", "sensor");
Homey.setClass("sensor");
Homey.addCapability("measure_temperature");
Homey.addCapability("measure_humidity");
Homey.addCapability("measure_rain");
Homey.addCapability("alarm_water");
void loop() {
Homey.loop();
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
int rainValue = analogRead(RAIN_SENSOR_PIN);
float rainAmount = 0.0;
bool rainAlarm = false;
if (rainValue < 500) {
rainAmount = 2.0; // Simuleer regenval in mm
rainAlarm = true;
} else if (rainValue >= 500 && rainValue <= 600) {
rainAmount = 0.5; // Simuleer motregen
rainAlarm = true;
} else {
rainAmount = 0.0; // Droog
rainAlarm = false;
// Stuur waarden naar Homey
Homey.setCapabilityValue("measure_temperature", temperature);
Homey.setCapabilityValue("measure_humidity", humidity);
Homey.setCapabilityValue("measure_rain", rainAmount);
Homey.setCapabilityValue("alarm_water", rainAlarm);
delay(5000); // Update elke 5 seconden
Hoping someone could point me into the right direction, so I can get it to work and continue to print a casing for it.
Thank in advance
