Homey support for Airzone Zoning systems
Hi
My first post here!
Are there anyone that are working on creating an app for Airzone zoning systems that are not supported by the Airzone Aidoo app? As I’m not able to connect to my Airzone cloud service with the Homey. But I can connect to the Airzone cloud service with my Amazon Echo, but the Echo doesn’t solve the controling as I would like to do it.
Airzone webserver:
My intention is to prevent heating/cooling with flows in Homey with the same magnet sensors for doors and windows as I plan to use for other flows in the Homey (if I connect the magnet sensors to the Echo I can’t use them in Homey and visa versa).
Thanks in advance.
Hello there, were you able to figure this out? I’d like to connect my airzone cloud to honey, any ideas or app available?
Is there someone who succesfully installed this app on a Homey Pro 2019. I can’t get it working. Getting user name and password question. Do you initially let the Z-Wave on the Homey discover the device or “only” this app? Thanks for the info.
Hi, I just released this app that is compatible with the Airzone local api.
I have a problem with the Airzone App, I can’t connect to my web server with IP. I have the following error : webservers is not iterable …
Everything was ok in Home assistant can some one help ?
Thank you
Hello same error for me… :frowning:
Hi, I found the solution. You have to update you Airzone Web server.
You can do it directly on the Airzone app, once the 4.13 firmware version is installed it detected my Airzone and worked well
Hi, ok thank you, is it a Airzone webserver cloud that you have ?
I’m trying to update it but it still remain in 3.21…
Hi, You might try with the web app. Didn’t manage to update with my phone.
