Homey Self-Hosted Server on Raspberry Pi | Megathread
Maybe the logs show some hints
Troubleshooting with SSH
In case you need to do some troubleshooting, you can open a remote connection with SSH or Raspberry Pi Connect into your Raspberry Pi.
To view the status of the service, execute:
$ sudo systemctl status homey-shs
To view the last 1000 log lines, execute:
$ journalctl -u homey-shs.service -n 1000 -f
src
However, it might be a non-existent issue, I don’t see v12.11.0 anywhere mentioned (yet). Who sent you the update news?
Hi @ the notification I received came into the Homey app
Ah that’s straight from headquarters.
But surely I can’t be the only one who got this message
I’ve SHS running as HA add-on & as linux docker image.
HA add-on needs a reboot to update, and the latter needs a docker pull, but while done that, both still run v12.10.1
So I’m not sure what’s going on, Ton.
I’ve already followed the update instructions several times, but that doesn’t change the version number. I’ll dig deeper tomorrow. Thanks for your feedback Peter
… same here, still on 12.10.1 on a RasPi 5.
The app says: No updates available.
But the app also immediately (!) says, when I want to create a diagnostic report: ā€œOverload meā€
Runs like a charm on the front, but I’ve looked into the back, viewed the logs today and it’s flooded …
sysop@Homey:~ $ sudo systemctl status homey-shs
ā— homey-shs.service - Homey Self-Hosted Server
 Loaded: loaded (/etc/systemd/system/homey-shs.service; **enabled**; preset: **enabled**)
 Active: **active (running)** since Thu 2026-01-08 16:27:01 CET; 1 week 3 days ago
Invocation: a1aec1c7b29644d3a3e362cbaf34f958
Process: 1093 ExecStartPre=/usr/bin/docker pull ghcr.io/athombv/homey-shs:latest (code=exited, status=0/SUCCESS)
Process: 1103 ExecStartPre=/usr/bin/docker stop homey-shs **(code=exited, status=1/FAILURE)**
Process: 1112 ExecStartPre=/usr/bin/docker rm homey-shs **(code=exited, status=1/FAILURE)**
Main PID: 1122 (docker)
  Tasks: 10 (limit: 9578)
    CPU: 23.120s
 CGroup: /system.slice/homey-shs.service
         └─1122 /usr/bin/docker run --rm --name homey-shs --network host --privileged --volume /homey-shs:/homey/us>
Jan 19 11:02:26 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:apps:getApps
Jan 19 11:02:26 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:apps:getApps → Success 200
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:getInfo
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:getInfo → Success 200
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:getSystemName
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:cloud:getState
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:cloud:getState → Success 200
Jan 19 11:02:36 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:getSystemName → Success 200
Jan 19 11:02:38 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:sendLog
Jan 19 11:02:38 Homey docker[1122]: Homey [log][ManagerApiLocal] IO homey:manager:system:sendLog → Error 501: Overload >
lines 1-23/23 (END)
and – hundreds of this:
Jan 19 10:34:25 Homey docker[1122]: Homey [err][ManagerInsightsLocal] Error Updating Number Log homey:manager:apps:nl.philips.hue-mem: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: RRD Error updating RRD logId: homey:manager:system:memory - file: /homey/user/rrd/5b9199bf4bd2e145c78a9a885e761e18 - value: 364.396544 - timestamp: 1768815260: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: Homey [err][ManagerInsightsLocal] Error Updating Number Log homey:manager:system:memory: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: RRD Error updating RRD logId: homey:manager:weather:humidity - file: /homey/user/rrd/dedd7e33f0e600fe439581b2c780b763 - value: 94 - timestamp: 1768815260: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: Homey [err][ManagerInsightsLocal] Error Updating Number Log homey:manager:weather:humidity: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: RRD Error updating RRD logId: homey:manager:weather:pressure - file: /homey/user/rrd/8ce5c7370a116596e880d5a48817c74a - value: 1.02 - timestamp: 1768815260: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
Jan 19 10:34:25 Homey docker[1122]: Homey [err][ManagerInsightsLocal] Error Updating Number Log homey:manager:weather:pressure: rrdcached@unix:/var/run/rrdcached.sock: illegal attempt to update using time 1768815260.000000 when last update time is 1768815260.000000 (minimum one second step)
… just pasting it here with ā€œ?ā€ in my mind, for now. :victory_hand:
@betaplar Thanks for your message. I reported this to Athom on January 16th, but haven’t received a response yet. The situation remains the same. I did disable experimental updates, which made the message disappear.
Please format the logs as preformatted text
That was my intention, but the text editor here in the forum wasn’t self-explanatory enough for me.
You could’ve asked, but this new manual is clear enough I hope?
… already fixed my posting :victory_hand:
I’ve tried to flash a new SD card via Raspi Imager, but there’s still only 12.10.1 available, that doesn’t update during boot-up.
So I guess patience is it!
Changelog still is at 12.10.0 Homey Self-Hosted Server Changelog | Homey
Maybe I am way too excited. Thanks for reading so far. :face_with_peeking_eye:
@betaplar I just downloaded and installed Homey SHS again on a test RPI. It’s also running version 12.10.1, and there’s no update available. No response from Athom yet, so we’ll have to wait.
Uhm, looking at Athoms github pages and the developer tools showed that 12.11.0 is indeed released and you need to update the image with the one that has beta tag at the end. I havent found a way to do this on RPi, but when trying on a ZImaOS instance I pulled it of with just changing the image in the docker compose file.
Package homey-shs Ā· GitHub
Today it’s actually released, Ton
@Peter_Kawa Thanks Peter, I was able to update successfully this afternoon. It’s strange that I’ve had the message for over a week and the update hasn’t worked. Athom only just responded to my email, by the way.
Hi everyone, I’m running Homey SHS on a Raspberry Pi 4. The update is showing up, but I can’t install it. How do I start the update? I’ve restarted SHS a few times, but it still hasn’t installed.
This might be related to the current cloud issues.
Restarting the RPi should do it, according to the fine manual:
https://support.homey.app/hc/en-us/articles/23975075444124-How-to-install-Homey-Self-Hosted-Server-on-Raspberry-Pi
