Danfoss Ally™ - Danfoss’s new front runner in smart heating solutions.
What kind of category signal would the app use :
Zigbee
Danfoss Ally™ Radiator Thermostat is a Zigbee 3.0 certified product, compatible with Danfoss Ally Gateway™ and with third party systems using Zigbee protocol.
**What kind of device would you like to be added:**
Cooker hoods and kitchen fans from Fjäråskupan
Swedish premium manufacture of cooking hoods.
**Brand, and id number(s) of device(s)**
All ther devices that can be controlled by app or remote.
**What kind of category signal would the app use :**
Bluetooth
**Is there a (public) API / documentation / manuals or known other implementations (like Blogs/Github etc)**
No, need to contact manufacturer.
fjaraskupan.se
**Are you willing to loan or donate a device or money to a developer?**
Hard to loan a cooking hood, but I help trying it out.
Manufacturer also seems helpful with intresting projects with their devices.
What kind of brand/device(s) would you like to be added:
High end audio
Rotel Stereo Preamplifiers / integrated amplifiers
eg. Rotel RC-1572 - Seems to use a generic command list compatible amongst all like Rotel products.
What kind of category/signal(s) would the app use:
IP (Local)
RS-232
IR
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
An implementation of RS-232 control for Home Assistant exists already:
RS-232 commands and response format is the same for IP.
Commands will be accepted via TCP port 9590, and the unit will send responses back via
the same port. The command and response format is identical to the serial commands.
Further devices and information are readily available and easy to find at:
Are you willing to loan or donate to a developer?
Happy to test with my device, this project is pretty straightforward given existing development and easy access to protocol and information.
I can offer a small donation to get it rolling.
Extra information:
Other units are also available for control, so this app has the potential to be expanded to an entire product line without too much extra work. I am not a professional installer, otherwise I would offer to support this project financially but I can see the potential given this high end brands position in the market place.
What kind of brand/device(s) would you like to be added: ioBroker
What kind of category/signal(s) would the app use: MQTT via Wifi
Extra information:
Should be very close to the HomeAssistant adapter…
ioBroker has very powerful visualisation capacities, far more than lovelace. As there are probably many users trying several combinations, an ioBroker adapter would be a great enrichment for Homey!
App for inverse time over-(current, power, voltage, temperature, etc) protection.
No communication protocol.
Basic idea of inverse time overcurrent protection can be found here.
Yes, donate money 20€, when there is working app
Willing to make pseudo code for the app and check the coding into some extent and definitely test the app.
Extra information:
Some application examples:
If your household electrical inlet has for example 25A fuses, you could make a “software” protection with this app. If the current exceeds the tripping limit of the inverse time overcurrent characteristics some of the loading is switched off and prevent the fuse from blowing.
The definite time characteristics could also be implemented in the app.
**Ultrasync, Interlogix, Caddx **
Brand name, and any (available) id number(s)/types of devices
Interlogix, Caddx home alarm system.
IP (wLocal/Cloud/WiFi);
There is an integration on the Homebridge platform.
Link(s) to where can this be found, the more information, the better.
