[Homey Pro 2023/2026/mini] Informationen und Diskussionen zu neuen Firmware-Updates
Homey Pro (Early 2023) v10.1.0 has been released to the stable channel
Core
  • Fixes an issue where a zone could be its own parent.
  • Fixes an issue where apps could not always retrieve image streams.
  • Fixes an issue where the “The temperature becomes greater/less than °C” Flow card would not use Fahrenheit in countries using the imperial system.
  • Adds a Flow card for sending raw pronto hex IR commands (available through the Power User experiment).
  • Fixes an issue where App insights were deleted on reboot.
  • Fixes an undefined timezone for some users.
  • Fixes an issue where the time range in Insights would not use Homey Pro’s timezone.
  • Fixes an issue where the “Start a Flow” Flow card could not start Flows starting with a “when” Flow card containing an argument.
  • Logs memory usage of Homey Pro to Insights (available through the Power User experiment).
Bluetooth Low Energy
  • Improves BLE memory usage and performance.
433 MHz & IR
  • Increase max message length to support longer IR and 433 MHz commands.
Z-Wave
  • Updates Z-Wave firmware to reduce TRANSMIT_COMPLETE_FAIL errors.
  • Improves message retry mechanism.
  • Adds support for Command Class Meter V6.
  • Adds power measurement capabilities to unknown Z-Wave devices (if supported by the device).
Zigbee
  • Adds power measurement capabilities to unknown Zigbee devices (if supported by the device).
Satellite Mode
  • Adds functionality that enables Homey Bridge to act as a Zigbee router.
    Matter
  • Fixes an issue where Matter Bridges with many bridged devices could not be paired.
  • Adds support for Matter window coverings.
  • Adds support for Matter buttons.
Wi-Fi
  • Updates Wi-Fi driver to latest version.
    Presence
  • Fixes an issue that could cause presence Flow cards to be triggered twice when the presence state of multiple users changes simultaneously.
Setup
  • Fixes an issue where enabling setup twice in a row would fail.
