New to Homey. I’m converting from SmartThings. I am putting all my water leak sensors on Homey but theres no app for my Zwave Fortrezz water valve on Homey. Is there a way to send a “message” between Homey and SmartThings to trigger the water valve kept on SmartThings if the Homey water leak sensor gets trigger for a water event? Thanks!
Figured out a workaround. Using an IFTT Applet: If Homey water leak sensor detects water then switch on (turn Fortrezz Water Valve) running on SmartThings. In order for IFTT to see the Smartthings Fortrezz Water Value as an available Applet device I had to change the driver for the Water Valve to a “Z-Wave Switch” from a “Z-Wave Water Valve”.
