thats the link i tried… past my long token after it and it says token invalid… my token is verry long with dots in it ?
Ur token is longer then u think. Plz make sure u have the complete token!
Yes, working well in Fully kiosk
Thanks @Eduardo_Rodriguez It is available now, please use lang=es
An easier way to do this:
After a successful logon at homey.ink click on the link in the console.
When the page is loaded replace app.homey.ink/?theme=kobo-h2o in de address bar with homeydash.com/?theme=web
Open the page in Chrome. After logging in hit F12 or any other key to open the console, and then choose console
Damm… you guys are great!
it works! thanks for support
Anytime. The link btw is https://homeydash.com/?theme=web&lang=en&token=TOKEN
As there is a bit of confusion about different versions of the Homey ink we created a seperate topic for the online version. So for the Homeydash.com version, the online version , please go to this topic.
@DaneedeKruyff
I was asked by a friend if it is possible to make a info panel, same as battery, but with temp and moisture from all sensors… ?
Good idea ?
Would it be possible to display stuff from specific rooms? Rather than favs thus I can customize each tablet in each room to just display what’s in that room
From the first post:
Reply in the new topic:
Tried this, but get for every user the same token. So one token for one homey
For me this works, create different homey users, activate these, then go to homey.ink logon with your other users, copy the token for that user, have 3 different tokens now
Will give it another try
Peter, can you release your version of it? i like it ![]()
@DaneedeKruyff is it correct that i now can’t switch between sensor info anymore?
also i now have a few light group’s i can’t turn on or off anymore?
Edit: never mind… just seen that there is a new community page for homeydash.com xD found my solution!
