Homey Dashboards | Megathread
Thanks Athom for the great work!
I, however, think I ran into an issue regarding device type filtering:
Smart relais with the “Plugged in” attribute set to “Lamp” do not show up in device widgets when “Lamp” is set as device type filter.
Above device is a Z-Wave device with “Device Class (Generic) = GENERIC_TYPE_SWITCH_BINARY” that does not show up when setting the device filter to “Lamp” although I think is should(?).
This also happens with Zigbee devices.
…and a question to Athom:
Is PIN protecting devices (e.g. switches) and/or dashboard pages (as e.g. possible with SharpTools) on the road map? Will it become available anytime soon?
Where do i find the purchasebutton as beta tester?
Afaik you’d install the newer live version now.
Wat bedoel je @Peter_Kawa?
Ik doe mee met de Apple Store test (TestFlight). Moet ik deze nu verwijderen en opnieuw de Homey app downloaden vanuit de Apple Store?
Het is mij nu ook niet helemaal duidelijk wat ik moet doen. Er vanuit gaande dat de Dashboards nu in orde is en je kan aankopen?
Sorry:
What do I mean @Peter_Kawa?
I am participating in the Apple Store test (TestFlight). Should I remove it now and download the Homey app from the Apple Store again?
It is not entirely clear to me what to do. Is there a good that the Dashboards are now in order and you can buy?
And suppose I have to delete my app, will the dashboards still be good so that I can get them back and have to reinstall them?
Not in store yet overhere i’m afraid
Dashboards is much appreciated. Thank you! Excited to see more widgets develop. I understand dashboards on the web app might be complicated (because of browser limitations?). However, Advanced Flows works beautifully on the web app. It would be great to have everything on one device. Any plans to get Advanced flows on iPad app / Mac OS app?
You can not purchase anything in the beta version. Go back to the latest stable version, make your purchase and go back to the beta again ((thats the way I did for backups)
Then i just keep it for free :wink:
Yup, never upgrade the beta app anymore :crazy_face:
@4x4_Pete thank you for reporting, we made a fix for this and it will be working next release :+1:
Thanks for fixing the license problem this quickly! However, app version 9.0.1 is not available on Google Play Store yet - at least not at my phone. Are there any estimations about when it will be available at the store?
Het blijft een “vreemde” situatie dat je als dank voor het testen als beta tester de volle prijs voor het blijven gebruiken van de feature moet betalen. Een korting was wel het minste wat redelijk zou zijn, maar nee …
Lijkt een beetje op Apple praktijken, valt me erg tegen van Athom :frowning_face:
Hello Bas
I see you have the ISS widget, can you tell me how to get it??
I cant find it anywhere.
Greetings Igor.
Line Chart widget - why can not multiple insight values be selected, have I missed something?
Snip from Insights webb app.
@Igor_van_Vegchel You can get it by installing WidgetBoard:
You didn’t have to test it of course. It was clear from the start that Dashboards would be a paid upgrade.
You can also turn it around: you have already had an advantage because you were able to try Dashboards for free, while others now have to pay for it right away.
And for such a major feature upgrade of older hardware, a one-time fee of 25 euros is not much…
@Marcel_Harberink & @Henk_Renting
Please in English…
4 things which will make dashboards a lot better:
  1. Be able to pick a start-up dashboard. Why do I need to click all the way to the right dash.
  2. Being able to create my own sequence instead of adding numbers in front for ordering.
  3. Make it possible for widgets to have the size of 1 card so you can out multiple next to eachother. Like a device widget for the airco next to the flow widget which will run them for 30mins. Takes up 2 full rows now.
  4. Put a dash shortcut in the homey widget where you can arrange a quicklink to your dashes.
