I also have a dahua NVR with 4 cams. Also get the message could not find that pair session.
Turn of onvif
I used this link:
http://“IP address of camera”/onvifsnapshot/media_service/snapshot?
The IP address has the following format (so without the quotes): 123.123.123.123
Good luck!
Regards,
Will
Hello
Thank you
If I put that link with IP from my NVR in Homey then I get the message could not find that pair session.
Did use setup something in the NVR or ?
Make sure under Network > PORT > ONVIF
Authentication is set to OFF
I am not using a NVR btw! All camera’s are directly added at Homey via the above URL
Onvif is off
In the link mist I put an username and password?
And are your cameras private or?
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards at
https://community.homey.app/c/non-english
Nederlands (Dutch), Dansk (Danish), Deutsch (German), Svenska (Swedish) , Français (French), Polskie (Polish), Fiński (Finnish)
My Dahua NVR snapshot url will work in my browser but in honey get an http error 401
Download Dahua app and connect each camera. There is csreenshot flow aswell. You wont need to play with http orders.
I like hikvision but havnt been able to connect them to homey
That don’t work get one camera . I have an nvr
Why dont you connect each camera separately? I have 4 cams in nvr but i connect cams directly to Homey.
How do you do that?
I can’t fill in the internal Ip’s addresses they won’t connect because they behind the NVR I mean
Hi everyone, someone can help me ti decide how camera buy to connect to homey ? I’ve to buy 4 camera for indoor and 4 i think outsider, and it’s possible connect any smart doorbell?
Most nvr’s have a virtual server function. You can then use the ip of the nvr in combination with a port number to connect to the camera directly. I’m using this to connect to 4 cams connected to a hikvision nvr.
Hello
He’s is see that but in de Dahua App het An error error exonreset en econrefused
I have a problem with my Lutec camera.
All was fine, pictures were sent from flows.
But since some days, Homey can`t connect to the camera.
It displays only a EHOSTUNREACH message.
The URL works fine in all browsers. Homey and camera are in the same network, the same IP range, and the same Wifi network.
I have no idea what has changed. Has someone this error, too?
I’m not sure, but I would say the error appers since the last firmware update.
The URL is:
http://192.168.xxx.xxx/webcapture.jpg?command=snap&channel=0
Perhaps Homey has a problem with the parameter?
Some other wabcam URLs are displayed in Homey. They have no parameter, only the jpg file.
Edit: corrected URL (192.168 instead of 192.169)
Perhaps a typo, but ip adres you have provided in the link is:
192.169.xxx.xxx
Normally this subnet is not in use for home networks.
192.168.xxx.xxx is allowed
Of course, it is 192.168… Corrected in privious post.
Just a typing error.
I have the same camera from Neo and I am not that lucky/handy than you. Could you copy me the link you fill in honey?
