Is there someone who has connected Homey with Tasker for Android and could share how, if possible, to start a Homey flow from Tasker and a Tasker task from Homey?
DirkG
January 3, 2022, 5:05pm
2
I don’t use Tasker, but I used the search function of the forum. Maybe this answers your question:
What are these tutorials for?
If you need to read this, then this tutorial is probably not for you. I’m going to assume you know your way around Tasker (Android Automation App) and / or KLWP (configurable live wallpaper) and you know how to create Profiles and Tasks within Tasker or how to edit your live wallpaper within KLWP. If so, with these tutorials you should get an idea on how to use Tasker in combination with the Homey API. Occassionaly I’ll be using some other tools as well, mostly from…
Quite often I like to use my Android smartphone to directly start a Homey flow, operate a Homey device or to put data into Homey flows without using the Homey app. If you would like to do the same, then this tutorial is for you.
What will be addressed in this tutorial:
Install Tasker on your Android smartphone
Install Join on your Android smartphone
Find device ID and generate Join API key
Create Join URL
Configure Tasker and Join to react to a received message
Setup the webhook in a Homey fl…
