I have an issue with the luminance being updated in homey from my Hue motion Sensor. It seems to only change when i go in to the hue device in homey. My issue is that I have a homey flow that uses the luminance card and checks the luminance to only allow the lights to come on if below a certain setting. Problem is, when my lights do come on the lux jumps up, expected that, but then homey holds on to that setting even after my lights go off. This means that my lights do not come back on even if the motion alarm is yes.
I have the same sensor and don’t recognize this problem.
That being said, you do have this issue so could you answer the following questions:
when you check the insights of the device do you see changes in the Lux graph at all ?
could you share the flow you use so we can have a look if something can cause this or perhaps can fix the problem ?
Where did you place your sensor? (Close to a window, lamp, a dark spot in your room?)
