Hidden Motor & Full Smart Blind System – Zemismart Zigbee Shade Options Now Working with Homey
:window: Smart Shade Setup: Homey Compatibility & Installation Options
We have been testing our Zigbee roller blind motor solution with Homey-compatible gateways to ensure stable integration and reliable daily use in smart home setups.
During this process, we also found that different users have different installation preferences:
  • Some users prefer a flexible motor-only solution for custom blind systems and integrations
  • While others prefer a more convenient, fully assembled ready-to-use product for faster installation and easier deployment
To support both scenarios, we provide two options based on the same Zigbee platform, both designed to work within the Homey ecosystem.
:gear: Option 1: Hidden In-Tube Zigbee Motor (DIY / Custom Build)
:magnifying_glass_tilted_left: Installation Concept (Contrast View)
  • Motor fully hidden inside roller tube :white_check_mark:
  • Clean, minimal interior design
  • Looks like a “real finished blind” after installation
:pushpin: Key Specs:
  • Zigbee communication (Homey pro compatible)
  • 100–240V AC wide voltage input
  • In-tube tubular motor, suitable for 36–38 mm inner-grooved roller tube
  • Supports up to ~5kg load
  • Precise percentage positioning control
  • Electronic upper & lower limit setting
  • Low-noise operation for residential use
  • RF remote backup control
:brain: Homey Use Cases:
  • Percentage-based blind positioning
  • Open / close / stop control via Homey
  • Multi-blind grouping
:window: Option 2: Fully Assembled Smart Roller Blind (Plug & Play)
DIY system:
  • Flexible but requires assembly :gear:
  • Motor + tube + fabric installation needed
Ready-made system:
  • Fully assembled blind shipped ready-to-install :white_check_mark:
  • No assembly required
  • Faster deployment for end users
:package: What’s Included:
  • Pre-installed fabric
  • Integrated in-tube motor
  • Aluminum roller tube system
  • Fully assembled blind unit
  • Ready for mounting + pairing
:house: Homey Integration (Both Options)
Both solutions support the same Homey experience:
:brain: We welcome any valuable feedback and suggestions, and feel free to contact our team if you have any questions.
