The variables are created and filled by the script already.
First, make sure to run the script minimal 1 time in HomeyScript editor, so the variables are getting created and become available and findable from the flow editor.
Flow:
You can simply run the script from a AND card (go to Homeyscript in the list, and then select the script), and as action, create a notification card and select the variable [windowText], which is grouped under “Homeyscript”.
Screenshot of the action card while the “share a flow” doesn’t display the variable:
Result pushmessage (it reports an open door and window):
